Skip to main content
File IO
Netduino 2 and 3 can access up to 2GB of storage on a Micro SD Card which provide a persistent storage mechanism similar to a hard drive. This can be useful for storing application configuration information that can be read at boot-up, or for storing log information.
Network-enabled models have an SD card slot on the board, but models that don't have one built in can use an SD Card Shield.
Accessing and writing to an SD card is generally the same as in regular .NET. However, you'll need to make sure that the following DLLs are referenced:
  • Microsoft.SPOT.IO
  • SecretLabs.NETMF.IO
  • System.IO
When a SD card is inserted into the Netduino, it is mounted as the SD volume, so for example, a file called test.txt in the root directory of the card would be accessed via the following path:
var path = Path.Combine("SD","test.txt");
The other thing to keep in mind, is that after writing to a file, FlushAll() should be called on the Volume in order to force a write. Otherwise, when the file is written will be indeterminate.
The following sample illustrates writing some text to a file called test.txt to the SD card. It also outputs some general information about the card such as how much free space it has:
using System;
using System.IO;
using Microsoft.SPOT;
using Microsoft.SPOT.IO;
using System.Text;
namespace SDCardIO
public class Program
// some debug output for funsies
OutputSDInfo();
var volume = new VolumeInfo("SD");
// check to see if there's an SD card inserted
if (volume != null) {
// "SD" is the volume name,
// write some text to a file
File.WriteAllBytes(path, Encoding.UTF8.GetBytes("Foooooooo"));
// Must call flush to write immediately. Otherwise, there's no guarantee
// as to when the file is written.
volume.FlushAll();
} else {
Debug.Print("There doesn't appear to be an SD card inserted");
public static void OutputSDInfo()
var vInfo = new VolumeInfo("SD");
if (vInfo != null) {
Debug.Print("Is Formatted: " + vInfo.IsFormatted.ToString ());
Debug.Print("Total Free Space: " + vInfo.TotalFreeSpace.ToString ());
Debug.Print("Total Size: " + vInfo.TotalSize.ToString ());
Debug.Print("File System: " + vInfo.FileSystem);
} else {
Debug.Print("There doesn't appear to be an SD card in the device.");
