Netduino has an accessible button and a blue LED onboard. This means that you can test code that uses a button or LED circuit without having to build an external one.
The onboard LED is availble via the Pins.ONBOARD_LED
enumeration, and turns on briefly when power is turned on, as well as after booting to indicate the OS is operational and the program is ready to run.
The onboard Button is available via Pins.ONBOARD_BTN
enumeration, and if not bound to either an InputPort
or OutputPort
, will reset the Netduino by default when pressed. To disable it, simple assign a port to it.
Note that the Netduino also has a white power LED indicating the board is powered. Boards that are network enabled, such as the N2+, N3 Ethernet, or N3 WiFi also have a network LED that lights up to indicate network traffic.
Netduino.Foundation PushButton and PwmLed
Both the onboard button and LED can be controlled via the Netduino.Foundation PushButton
and PwmLed
classes, respectively. These classes provide a modern, clean API for interacting with these peripherals.
This guide is provided for information on accessing it via the low-level .NET MicroFramework classes.
InputPort and OutputPort
Both the onboard LED and Button are accessible via an OutputPort
or InputPort
object. For instance, the following example illustrates turning the LED on when the Button is pressed.
using System;
using Microsoft.SPOT;
using Microsoft.SPOT.Hardware;
using SecretLabs.NETMF.Hardware.Netduino;
namespace OnboardButtonAndLed
public class Program
// An output port allows you to write (send a signal) to a pin
static OutputPort _led = new OutputPort(Pins.ONBOARD_LED, false);
// An input port reads the signal from a pin (Should be Pins.ONBOARD_BTN, but there is a bug)
static InputPort _button = new InputPort((Cpu.Pin)0x15, false, Port.ResistorMode.Disabled);
static bool _buttonPressed = false;
// turn the LED off initially
_led.Write(false);
// run forever
// set the onboard LED output to be the input of the button
_led.Write(_button.Read());
InterruptPorts
Just as with other digital inputs, the onboard Button can be wired up as an InterruptPort
to raise an event when it is pressed. For more information, see the Digital IO guide.
See Also
These docs are open source. If you find an issue, please file a bug, or send us a pull request. And if you want to contribute, we'd love that too!
